Something ive notices about 2 cycles
cpurvis
I have six 2-cycles. Some slobber; some don't.
All get the same gas and oil, just different ratios. The 16:1 Poulan Micro XXV chainsaw is one that doesn't slobber.
Hammermechanicman
The new synthetic and semi synthetic oils don't burn like the older oils. A lot depends on how hot the muffler runs. And that depends a lot on the equipment design and how the customer runs the equipment. I run my hopped up chainsaws at 40:1 Red Armor and they don't drool oil. Some other equipment at 50:1 Red Armor or Stihl oil or Stens drool like a baby. I have about a dozen things with 2 stroke motors. I don't woory about drooling or not drooling exhausts. When in doubt run it wide open all the time for best results.
Back in the old days of mixing engine oil to make two stroke it was a routine maintenance job to remove & clean the mufflers of a build up of soot, coke & oil
Hammermechanicman
My frazier Rototiller manual says to mix 40wt oil 16:1. Modern 2 stroke oil works fine at 40:1.
The original 16:1 mix used 30w non detergent motor oil.
