jpadie
- May 17, 2020
- 2
- 11
Thank you. I reset the throttle/choke cable and ensured that the butterfly valve was fully closed and retightened. Unfortunately that did not resolve the issue and the nozzle was clean when disassembled.
closing the engine side butterfly valve does consistently start the motor however. The governor does not seem to leat the butterfly valve go further than about half closed.
Is this a sign of a bad carb or a bad governor? or both?
