so much confusion on Kawasaki oil filters.
upupandaway
I went with the shorter filter on my Gravely 0-T. Short or long filter- I figure this small engine does not pump as much oil as a 4IL so it shouldn't make any difference. I would be nervous of 2 parts rubbing up agains each other. my ₵₵.
Remember that most of these engines worked fine for 30 years with no oil filter at all I feel all of this fuss about filters is 99% engineering ignorance .
It is very rare for a mower filter to be dirty enough to trip the bypass even if it has never ever been changed
I have had some cubs come in with the dirtiest oil I have ever seen, burn't to treacle yet the filters happily passed the oil and still did not create enough back pressure to trip the bypass.
As for oil coolers, well they were all the rage when I was young on motorcycles because RACE bikes had them .
Most of them actually cause damage to the engines by preventing the engine oil from getting to full operating temperature .
Small engines are fitted with coolers if they are going to be used in equipment that operates for very long times continiously like in skid steers , generators & compressors
Unless you are a commercial mower and mow 25 acres in a single session then again the oil coolers are potentially doing more harm than good unless you fit a very expensive one with a thermal bypass valve .
When I was a spotty faced teenager thus automatically knew better than the engineers at BSA I fitted a big oil cooler to my A10
I took it back because I was sure it was defective because it never got hot & was bypassing all of the oil
After the 2nd replacement, the distributor asked me to bring the bike in
He fitted a temperature gauge to my oil tank and asked me to record the temperatures .
In 3 months , it never got above 72 deg C
Full oil temperature is 80 C which is what the bypass valve is set to .
I learned a lot that month and where possible have always fitted some sort of thermometer to my oil tanks and yes the oil rarely ever gets above 85 C no matter what the air temperature is or how much I am abusing the motorcycle
Hammermechanicman
Always like it when folks agonize over the "best" oil filter for their mower and "bigger is better". Millions of engines on OPE have run millions of hours without an oil pump or filter with no oil related failures. Thousands of Continental and Lycoming aircraft engines and VW car engines don't have oil filters. Use whatever helps you sleep at night.
If you are really worried about dirty oil get a centrifuge filter. With that there is a limit on effectively a spin on filter works. What matters more is the microns that they filter down to. Some the Macks I change oil the regular filter were just normally dirty but the centrifuge filter were like bricks weight wise and these filter are after the standard filter.
Any way this thread is like which oil is better threads everyone has an opinion and most are just BS.
It does matter how good of a oil filter you once the oil starts to break down it just catches most of the metal filings from that point on. It like the HG EZT I tore down yesterday the filter screen and magnet complete covered in metal filings. So the oil failed to do its job. If the oil did it job there would been very little in metal filings. Now it is a complete time.
Travis R.
I had a Lycoming aircraft engine on an air boat years ago. I believe it was a 160.
7394
Ain't that the truth...
fieldhand1
I saw something a few years ago on this subject and at that time someone recommended Fram PH3600 filters. I have been using them for the past 3 years and so far it has been good. Seems to be about double the capacity. This is on a Kawasaki FR691.
this is what i have used for the last 10 years.
7394
Fram ? Seriously, yeoww.. Not for mine.
clubairth
I prefer to use WIX which is also the same as NAPA Gold filters.
7394
Wix is good.
