Snowblower not running well after some welding on it
spancwhitey
  • / Snowblower not running well after some welding on it
Just did some welding on bottom of blower now it seems like timing is off?
Darryl G
Can you please elaborate on the symptoms you're experiencing? You're not giving us very much to go on.
tom3
Welding is a pretty low voltage with a lot of amps, wouldn't think that would damage any ignition parts. And usually the more delicate parts either work or they are dead. I'd check all the basics first.
Catherine
LawnWorld Support
Welcome to the forum!
Hopefully, we can find you some answers.
The timing chip runs in the micro volt range so 12 V to it is like 1000V to you,,,,pooof .
7394
Did you disconnect the blower battery prior to welding ?
tom3
Looks like he's gone. I'd suspect he tilted the machine way back to do the welding and stirred up some dirt (or water) in the carb. Maybe already smoothed itself out?
7394
Sounds plausable for sure.
