oldlawnguy
- Jul 6, 2019
- 8
- 121
Snapper Model 130.887650 Dual Stage 27" 11.5 TP Snowblower
Wanted to replace both driver and auger belts, however could not figure out how to do auger belt as can't quite get clearance to remove drive belt as well as replace new one. The square metal plate on one side and the friction wheel on the other leaves not enough clearance for old/new drive belt which is much thinner than auger belt.
Replacing auger belt was easy when you v-split the auger from frame so I did that.
Stumped and looking for some pointers.
Pictures attached.
Pictures attached.
