Kmac
- Aug 9, 2020
- Threads
- 1
- 5
I had been considering a battery powered mower for some time and my wife surprised me with a snapper xd for Christmas. When mowing season came around I noticed there was two problems with its design. The snapper xd has "load sensing" and adjusts the blade speed based on the thickness of your grass. Heres the problem. I have fescue and my Honda gas powered mower does two things that are huge advantages for my yard. The Honda appears create a vacuum and cut the grass blades even and more importantly picks up and mulches the pinestraw and pinecones from the many trees I have in my yard. When I mow my xd the yard does not look great because it leaves all the debrie(unmulched) from the pine trees. The snapper xd does OK job when load sensing had the blade speed turned up. Here are some things I have considered.
1. I have ordered what appears to be their mulching blade. I haven't received it yet and don't have much hope it will make a difference. I have a feeling spent money on a replacement blade that will not change the behavior of the mower.
2. Modify an existing 21 inch mulching blade for a different model to create a load on the motor.
3. Figure out someway to trick the mower to think it is in thick grass.
All suggestions welcomed.
