bouncer959
- Mar 9, 2013
- 13
There is a fuse in the starter circuit, I’d check that first. Sometimes they are hard to find. If not bad, it could very well be yours new solenoid. I had am customer with a fairly new DR Chipper brush cutter that had exactly he same symptoms. It would blow fuse, but then stopped blowing starter circuit fuse. I narrowed it down to Solenoid was bad. Went to Oriellys, bought one , put on, it started 3 or 4 times then nothing. Let the troubleshooting begin again. Checked solenoid, it was bad. Took it back, replaced it with a full size one for an older Ford pickup, (one mounting hole didn’t match up), that’s been two years ago, says he hasn’t had any problems starting since!
