This thread leads me to post an experience I had with vibrations.... mower is a G1800 Kubota, with a 54" deck. Mowing through some heavy stuff that had some fallen branches. Usually, no problems, but this time, all at once, the once smooth running deck began to really vibrate. Shut down the deck and the engine runs smooth. Re-engage the deck, and the belts rattle and shake. I assumed that a spindle bearing had let go. Dropped the deck, disconnected it and took it apart to look for the problem. Found NOTHING !! Spindles all good, gearbox perfect, idler good, belts good... what else?? I sat and looked at the critter, and spun each drive sheave, looking for damage. Found it... a small piece of wood (limb) had jammed into the groove for one of the belts. Every time that small piece went around under the belt, it caused the belt to tension up and then snap back. Picked the wood out of the groove, put it all back together, runs as good as new. Something worth remembering.
