BKBrown
- May 5, 2010
- 15
- 1,415
I'll try to keep this short - A neighbor has a new Snapper 33" 33175 BVE rear engine riding mower.
This machine runs fine until the blade is engaged and then it will nearly shake your teeth out ! We loaded it up and took it back to the dealer - the head mechanic rode it for a couple min. (out of sight), came back and said it was fine (normal) - just run it full throttle. Full throttle just increases the frequency of the vibration and J.R. is 84 and can't take that kind of shaking. It looks like the drive belt for the mower deck has too much free play and that is causing the shaking vibration.
Any suggestions ? :frown:
