Psychlopath
- Jun 8, 2014
- 16
- 64
I had this issue with a 12.5 IC L-head engine not too long ago. It was nasty enough that my electric starter would bog down...but I also have a slightly undersized battery on it for now.
It started after I replaced an exhaust valve that I couldn't get adjusted properly and was probably original to the engine, which has some serious hours on it. It was like there was too much compression...the best I could do was to gently pull the engine through 'till it opened both valves, then yank the cord or use the starter.
I checked valve adjustment again and put it closer to the max and it helped a great deal and it's still pretty easy to start with the cord or starter now.
I think I broke 3 pull cords, one of which let my elbow fly back and smash into the garage wall; there was much cursing and gnashing of teeth that day.
Good luck with it.
Good luck with it.
