Snapper S-50X pro
Shughes717
Well guys, I'm surprised this blog is still up. I have had my Snapper pro 50 for a year and I haven't found any reason to buy anything else.
The mower has performed flawlessly, the only problem I have is on a steep slope the rear wheel will spin if not careful because the casters in the front want to go into a different direction when you try to turn uphill.
Probably the same with any of them, but not sure.......Ron
Glad to hear you are pleased with your choice of mowers. When you get to that slope you may have to mow it up , or down hill. I wouldn't suggest doing it over a long steep slope, as you can lose traction going down hill and potentially roll over, but it is fine on a short sloped area. I have a slope like that with a utility pole in it. I mow up it diagonally, and slowly ease downhill at a diagonal angle around the pole.
