My mower dies when the brake is released with the engine running. What is the problem? Help!
G greg ray Forum Newbie Joined Apr 26, 2015 Threads 2 Messages 4 Apr 26, 2015 / Snapper riding mower #1 My mower dies when the brake is released with the engine running. What is the problem? Help!
I ILENGINE Lawn Royalty Joined May 6, 2010 Threads 39 Messages 10,181 Apr 26, 2015 / Snapper riding mower #2 Most common cause is a seat switch or associated wiring harness problem.
AnthemBassMan Well-Known Member Joined Apr 26, 2014 Threads 2 Messages 199 Apr 26, 2015 / Snapper riding mower #3 Does it run just fine with the brake on? If it does, check the safety switch. Sent from my iPhone using LMF
T Tinkerer200 Well-Known Member Joined Mar 14, 2015 Threads 4 Messages 913 Apr 26, 2015 / Snapper riding mower #4 IF you are needing to mow your yard, locate and disconnect the "kill" wire at the engine, mow your yard then check safety switches one by one. Walt Conner
G greg ray Forum Newbie Joined Apr 26, 2015 Threads 2 Messages 4 Apr 26, 2015 / Snapper riding mower #5 Where is the "kill wire" at the engine?
