Matt
- Yoke Play: Upon putting the yoke back on I noticed that one of the holes on the case was out of round. Quite a bit of play for the nylon bushing. I should have seen this before but I missed it. So that will take some thinking on the best way to repair. I don't want to let it go as this will effect the drive disk to clutch effectiveness. I've gone this far... why not. My first idea is to round the hole out with a step drill and then tig weld a zinc washer in the hole and then grind and redrill to the correct size. Maybe another idea. One good thing is putting all the tools to use....
Looking great Matt,
waaaay back , I was repairing a Volvo marine outdrive.... fortuneatly for me, ... a fellow that had done this before .... had his wife ( a hobbyist photographer ) take pictures of EVERYTHING he did , with explicit close-ups on EVERYTHING . He loaned me those photos ( which shamed those in the FACTORY repair manuaI I was using )
needless to say it was a piece of cake for me. From that point on I always took pics of ALMOST everything I worked on but used a shoulder held camcorder in those days on a tripod.. finally digital cameras became affordable Amen ! And as they say the rest is history... slow me down ..??? a little ... but when I DID NEED a reference there
it was .... I save all my photos to thumb drives and keep them organized (usually) ..(LOL) I for one truly love to see the progress in pics ... keep em coming ..later my friend ...Boobala
Progress...
- Main Chassis:
Things are going back together pretty smoothly. The Aux Brake cable I had to think about but with the images and some of the web's videos I did get it routed correctly.
- Engine Pre Mounting:
SO for the engine, I needed to recheck to see if the mounting locations are the same. Otherwise I would either have to redrill or make a new mounting plate. It looks like the 11Hp Briggs and the Honda GXV390-DE have the same mounting holes and crankshaft location, as shown.
11HP Briggs
Briggs Mounting
Honda Mounting Check is the same as the Briggs. Great!
Now I'll have to get some 5/16"x24 studs for the engine as two mounting holes are threaded. Stay tuned for more updates.
Matt
Any issue with crank diameter or length ...?? LOOKING GOOD Matt !!
Model: Snapper RER 28085S 28" HiVac w/low profile bagger
Background: I had been given this mower around 2000 with a leaky 8HP Briggs. I replaced that engine with a 12HP Briggs that lasted up until this past season. That engine lost compression and "dropped" an intake valve. Being the end of the season I did the old "steak" the valve seat to finish out the leaf season. Worked but knew it was time to redo the engine.
Going back to my first post, this Snapper has had an 8HP Briggs and then was updated to a 12HP I/C Briggs. The latest fell victim to overheating and "dropping" an intake seat. Up to this point there has been minor updates to the build that I have tried to explain. Now, the engine change from Briggs to Honda should take a little bit of modding to get installed. Some of the areas of concern are
- Fitment and shaft location and size - So far the GVX390 measures up to fit in the exact mounting holes with the same shaft size and dia. I created a mock template of the old Briggs to make sure the shaft location is similar. It was in the same location. If it wasn't, I would have had to redrill mounting holes to get the shaft placement correct. Otherwise the gears 1,2,3,4,5 & R would be off. One note is that the Honda has 2 threaded holes so I purchase (2) A: 5/16"x24X1.5" by B: 5/16"x18X9/16" studs and installed them with two nuts and loctite.
- Controls - TBD (Ordered 7075089YP)
- Electrical - TBD
- Fuel - TBD (To use the original Snapper tank or the Honda engine mounted tank.)
- Exhaust - TBD (Plan is to create a side exhaust as the Honda exhausts out back and I have a bagger)
