Off hand not sure if you have an internal governor or a flywheel governor as you have stated only the Briggs seris number. The number is either stamped on the sheet metal or on the crankcase. That said I shall continue.
And those of us with Briggs Power Portal access can look it up by the serial number too on the newer engines.
1910238424121
BTW this one was manufactured Oct 23, 2019.
