Snapper Ninja Disc Bearing 21" Mower
timc1018
Yes, there is another bearing on the other end of that "hex" shaft, that's held on by a o-ring and bracket. I'd replace that one (bearing/bracket/o-ring) as well, as that bracket also wears out causing the shaft to sit crooked. The bracket has a lip on it that centers the bearing and hex shaft, that lip wears out causing the shaft to sit crooked.
That's the bearing I was talking about on the lower as you mow, right side? Sounds like it.
