Snap Ring Help!
I cannot remove the pulley because there is some sort of snap ring I think holding it on the shaft. See picture. Any help very much appreciated!
2000 Dixie Chopper xw2500 trans pulley.
Ok I’ll heat up the pulley and see what happens. Thanks for the help! Much appreciated! It has been on there for almost 25 years. So stuck certainly sounds reasonable. I checked for an Allen head scr
So no luck so far. Anybody got any other suggestions? I may not have heated it up enough. I’m going to repeat the process several times tomorrow and see what happens. Sprayed it with pb blaster going to let that soak in overnight. Thanks for any additional advice.
Can't be using a propane torch; unless, it is boosted by O2. What you really need is an ACE/OX torch to produce heat quickly the enlarge the pulley before enlarging the shaft.
You are right! Don’t have ace/ox torch so I elected to cut it off. Found a new pulley and ordered it. Will let u know how it goes. Thanks for the info.
