2019 Z930M carbureted , New to this site
mower shutoff at idle and never started again , battery good , gas good , fuel lines clear
engine was turning over but no start , can siphon fuel from tank , part on carb is working
decided to change the ignition switch so the cover for the controls side was off , we got a blowing rain
the mower was under cover but moisture on everything , dried all parts i could get to, put terminals
back on battery installed new switch put cover back on then smoke pouring out ,burnt up the control module
and the connector plug , picking up new control mod and wiring harness this morning .
Anything else i should check ?
