SLTX1054VT
hlw49
Cub Cadet SLTX1054VT Model no. 13WR92AK010 BRIGGS 44P777-0721B1-090205YG Runs great engage the pto and runs about 10 feet and pto kicks off. Push pto off and pull switch again and does the same thing. Engage the mow on reverse button and it will mow all day. Anyone ever seen this.
Sounds like the reverse sensor switch is faulty
They are usually on the tranny near the right wheel
It is a ground circuit, often grooped with the seat switch so the wires can ge cchaffed and short on the frame
hlw49
Thanks I'll check it out
hlw49
Thanks Bert you were spot on the wire was broken. Just fixed and works like new. You are the best.
Having spent hours trying to fix the same problem only ti find it was a simple wire pinched in the controls tends to keep things fresh in your memory
Go mow
hlw49
Really fixing it up to sell. Turning out to be a reall nice mower. All new spindles idlers and belts tune up and service. I don't sell junk and have never gotten but two to give a problem. Ign module went out on one and PTO switch on the other. Thanks again.
