kingjames1
- May 12, 2014
- 38
OK is there fluid in the tank when it's cold ? Should be like and inch.
It's about an inch from the top. hmmmmmm?
Just looked at your pic. Yours is easy. Change the fluid and filter? and see what happens.
Put 2 quarts in still not full. Do you know how many quarts it takes? I'm going to pick some up tomorrow.
The oil is black and had a hint of burnt smell to it.
If you'll find which model tranny it is you can find the capacity. Or if you post it I'll look it up (try) for you. For sure when changing the oil you will need to purge the air from the system or the oil will not move properly to operate the tranny. If that screen shot is from a downloaded manual, see if it gives the capacity, internal/external filter, and how to change the fluid. Not to upset you however keep in mind the tranny might be fried. I'd still do the fluid change and see what happens.
I'm already upset. A little over 4 years old. Like to know what could cause that. My wife mows about 2 acres; that's it. She doesn't beat on nothing. We were told this Cub could handle 3-5 acres. If that doesn't fix it that will be the first and last Cub I buy.
One site said 2 quarts another said 2.5 quarts. I'll get one more and purge it. We'll see what happens.
