Slow/sticky right transmission...
The Chairman
When I mow, I'm finding a delay when I go from reverse to forward on the right side tranny. It wasn't there before, and it slowly gets going and then gets up to speed quickly.
The Chairman
I'm wondering if this is an adjustment issue, do I need to change the fluid again or do I need to rebuild the unit? If so, can I find a rebuild kit for it?
The Chairman
Nobody seems to care about this or has an opinion, so I moved on. However, in the interest of others having my problem and wanting a solution, I'll post how I fixed this. Youtube had a video on the subject that seemed to pinpoint the problem and so I was emboldened to go through the right transmission. Zero Turn Transaxle No, it wasn't perfectly my trans, as I had no oil pump where the input shaft conveniently extends through to be tapped on. However, being a mechanic for 30+ years, I pulled out the input using a slide hammer bearing puller. Just like the video, one of the check valves was loose, so I added a bit of Loctite Blue and hammered her home with my impact. I removed the other check valve and did the same procedure. I carefully scraped all the gasket surfaces and polished them with a roloc disc. I don't have my parts cleaner up yet, so I emptied 2 1/2 cans of brake cleaner to totally remove any particles in there. Since the trans was apart for almost a week waiting for the seal kit, each gear, bearing and shaft got the same treatment. Re-assembly was fairly straightforward, except for the very beginning when you have to assemble the pump with the six pistons and the servo with its six pistons sitting at a right angle to that. The springs make it hard to slide the pump in, so I got a nylon spatula, and trimmed it to the width of the pump body to help me press down on it while getting it to go. Wow. That was kind of easy. There was one nick on the spatula that troubled me. Next time, I'll trim a SS spatula so I don't contaminate the gears. My luck is that this 'nick' will wind up in a check valve at some point. Grrrrrrrrrrrrr. I hope it finds its way into the filter quickly and I don't have to worry about it. I went and changed oil in both units and then proceeded to get it primed. It took a push or two for the left side, but I was at it for a long time to get the right side all purged and working. It also took five quarts and not four. There was a lot of oil in the pump and servo that don't get changed during normal maintenance. No more hesitation though and it feels stronger than the left side now. Hmnnnn. I might pull the left side in the winter. The seal kit was about $45ish and the RTV was probably around $5. It took about 20 minutes to pull the trans, a half hour to disassemble, an hour to clean it, forty five minutes to re-assemble and another forty for the install and bleed. This was my first time in one of these, so I was in no rush to make time. Slow is smooth and smooth is fast. Not having to redo it all was priceless. I was comfortable enough having watched the video to not take lots and lots of pics. Caveat: There is one small part that is hard to see and took me a long time to find when I pulled everything apart. It gets mentioned in the video, but like the assembly of the pump/servo sub-assembly, it wasn't given proper attention. It's about 1/4" square and an 1/8" thick. It fits in a small cavity that's visible when you're putting in the servo output shaft, round side towards the shaft. It's the bypass mechanism and the shaft sits on it and allows the oil to bypass when we pull on the tab. Find it. Don't lose it. Don't forget to put it back. :D Oh yes: use assembly fluid liberally.
EDIT =>In the cost breakdown, I forgot the $55 of synthetic oil and the $12 in filters.
Now I am not trying to be demeening or abusive in any way shape or form but you don not seem to understand how this forum works.
It is not Face Book where every post must be responded to in less than 15 nano seconds.
Secondly there is a nice polite & slightly humourios method to draw attention to the fact your thread had not been answered :anyone:.
Unless a person has posted to a particular thread , they will have no idea if any one else has answered it .
Most of the regular responders use the "new post" search so unless there has been a response to a thread in the previous 24 hours they will not see a thread again.
There have been people who have ended up bumping their thread a dozen or so times before they got the information that they sought.
Also not every person on the forum has worked on every mower.
I for one knock over around 300 jobs a year but am yet to lay hands on a Huster so I am in no position to offer any meaningful assistance to you.
I agree with Bert, but thought I should add this. You started this thread on 7-14 and on 1-17 you posted this in another thread. “I run a forum for diving with many professionals, and we would not allow such an attack. With that, I'm out of your special forum here. Nothing here I really need. Have fun. Don't be so harsh with the noobs.” Maybe that is another reason no one responded. I also see very few Hustlers and 95% of the time I have found that when I find trannies with internal problems, due to our labor rate and cost of individual parts, it is cheaper to replace than rebuild, just using your times I would estimate $400. To that you should add new filter and oil, plus our time to diagnose, write an estimate and discuss with the customer and test unit on completion. Now if I thought there might be a leftover piece in the unit, it means triple check and find it, can’t pray it finds the filter first. Plus, being a commercial business we warranty our work like this for 120 days. New tranny warranty is one year. You don’t have to worry if you are working on your own unit, but every good business person and technician spends extra time double and triple checking even the simplest things, because comebacks can be our kiss of death. People who come here ask the professionals how they would fix a problem and it would be very unprofessional for us to advise them to bypass safety and do questionable things. To 75% of people feel that people in all repair businesses over charge people and only go to them when “Joe down the street” can’t fix it. Do you realize how much it costs the business and the techs each year in tools, diagnostic equipment, update schools and seminars, to meet the requirements of each manufacturer to do warranty work and be the professional you go to when you can’t fix it. On this forum we just ask for a little patience and respect in return for trying to help anyone. I’ll bet the same holds true for your business and diving forum. Hope this explains why we a a little harsh at times.
turboawd
Eh. Give him a break. I'm glad he posted what he found.
The Chairman
Now I am not trying to be demeening or abusive in any way shape or form but you don not seem to understand how this forum works. It is not Face Book where every post must be responded to in less than 15 nano seconds.
I first posted 21 days ago. You're the first to reply. Not sure how that is "15 nano seconds". I did want an answer to my query, but I certainly got what I paid for.
Bumping is often discouraged on many forums. It might be OK on such a slow forum and I'll try to remember that.
Oh yeah, I get it. That's why I gave up on an answer here in the Hustler section and moved on. Would you rather I lie and post a profuse "Thanks"??? There are other resources out there that had the answer and I don't mind pointing them out. I fixed the problem and did the right thing and posted how I fixed it. I even posted a link for the next guy who does a search here to find and benefit from.
Thanks! Hopefully it will help others.
The Chairman
A couple of notes. For some reason, I can't quote Rivets post. Maybe he has me on ignore or something. Don't know and don't care.
As I pointed out before, I was a professional mechanic for some thirty years. I've done more than my share of quoting, fixing and so on, but on cars. Fixing a frickin mower is so much easier than that. BUT, and I do have a big butt, I didn't ask in the pro corner: I asked in the Hustler forum. Oh, I've done my bit in the automotive and tire forums when the internet first became popular and I learned quickly to answer patiently and never tell anyone off: just like I do in real life. I like any forum I'm in to grow in popularity, and the only way to do that is to be friendly to everyone. People come here to ask questions because they have real problems and are looking to others for wisdom and hopefully some insight. It rarely moves at the speed of light and so a few of them get a antsy and do their best to draw attention to their plight. Never reply to impatience with more impatience. I thought it was a horrible way to treat others in the other thread and I still do. You may justify your meanness in any way that you want. Or... you can take my constructive criticism as it was intended.
Me? I want a zillion people in the Hustler section and I don't care if you're a professional or a rank amateur. Professionals built the Titanic while amateurs built the Ark. We can learn from each other and still be nice. The world needs more nice and the ability to take a little constructive criticism. Being nice is the way to grow the forum and make it a bit more relevant.
This is a big forum generally near 100 posts a day so no one worries much about people bumping , in fact we rather like it ( well I do in any case ) because when i see a thread that has not been answered meaningfully I get encouraged to do some searching.
i keep asking the admin to move the :welcome::anyone::newhere: emojies to the front page so they can easily be accessed and hopefully used more often.
It does lift the tone a tad.
There is no one on here who is fundamentally nasty and most are quite patient.
About the only thing that gets people cranky is poster who go off in a petulant hissy fit because they are not patient enough to wait for an answer or take offence that they have not gotten an answer.
And I have been in the same boat as you of the dozen or so threads I have started because I was stuck only 3 ever resulted in a meaningful answer.
And the nano second jibe was don to the first two posts about 90 minutes apart.
And credit where it is due it is good that you posted what you did to fix your mower so :thumbsup: we do appreciate that.
The Chairman
The second post did not chide the forum for an answer. I merely had another thought on the matter. I do that as I suss things out and often putting them down in writing helps.
Thanks. I do try.
There's not much out there that I can't repair. While I'm retired from the auto industry and am now working in the diving industry, time is still precious to me. I'm certain that time is precious to everyone here. I've been managing a very successful forum, think over a hundred posts an hour, for almost two decades now. Friendliness grows a forum, while snarky, off topic rants because someone shows a bit of urgency will keep a forum small by running off all the noobs. Instead of complaining how horrible a person he is for giving us a poorly worded question, show some compassion and spend more time answering his question than bashing him for his lack of netiquette. It's easy to smack someone down... let's try to encourage them instead.
