I was wondering if there was a way to slow down a rer besides throttle it down. any thoughts.
Ok I have a rear engine rider series 23, Model 281223BVE, It has the clutch disc on it which I have just replaced. I know the request is a bit out of the ordinary but if there is something someone might suggest that would be great
I am having a similar issue with a 2013 RER Snapper. The problem is that it does not have a detent for every speed like the old ones. It has one at neutral and one where is goes too slow for what I would consider normal mowing. If you move it out of that detent the lever moves forward on it's own about an inch and goes faster than I want.Also you may want to check the Shift Detent. See attached pic
