shadetree#1
Did you adjust the intake valve per the Service manual at 1/4 inch past TDC of the piston?
If you did this and your set the intake valve at .0025 at 1/4 inch past TDC of the piston and it still hangs insert a feel gauge under the rocker arm so as the clearance becomes .0005 to .001 and test crank. (do not adjust just insert a feeler gauge so as to reduce the intake valve lash and check the crank)
Doing this test is checking the condition of your Automatic Compression Release (ACR) so as to get an idea if it's broke or just worn down somewhat.
