Simplicity deck height adjustment motor
pabird
What the heck is going on? Sure hope someone can set me straight on this. My Broadmore 48" fabbed deck height adjustment motor won't work from the dash switch. I've checked for power at the connector at the motor and get +12v and -12v from the switch. I then put 12v directly into the motor through the connector and the motor works fine. Great. Must be a faulty connector. Replaced the connector and it still doesn't work! I really don't know where to go from here. Any help appreciated.
Try putting 12VDC directly to the connector at the switch. If motor runs bad switch, motor doesn’t run bad wire or wires between switch and motor.
unplug harness from rocker switch behind dash, brush dirt away with old toothbrush etc. at both connections, apply Dielectric Grease to rocker switch & reconnect harness to rocker switch & give her a try, also check attaching points at rear of deck.
Thanks for those ideas. I'll give them a try first thing Monday. Been a little crazy around here!
Ok so I cleaned the contacts at the switch, still won't work. I put power directly to the connector at the switch and the motor works. Although I had previously checked for power at the connector after the switch and got +12 and -12volts I ordered a new switch. I'll let you know how it works out.
So here's shot in the dark - Just purchased a new Broadmoor w/48" deck - obsolete and Classic. Got a good deal. Looking for a mulch kit or blocking plate. According to dealer, Simplicity didn't make such a kit. Anyone know if one is available? trying to keep the grass out of my beds.
