Simplicity Coronet Charging issue
lorenl
Checked the amp DC and it was 2.45 at full throttle.
Thanks for the help.
lorenl
I got to looking a little closer and the neutral safety switch (purple and yellow wire) had been tied together to bypass that switch. Could it be the regulator had been removed since the black wire coming from the stator goes nowhere else after the white connector.
