I own a 2003 simplicity broadmoor (model 1694010 with a 38" deck - 986017) and I had to replace one of the bearings in one of my spindles. I replaced the bad bearing (top only - it was destroyed), the hub and the foam gasket and put everything back together. I can't get the bottom bearing out because I can't get the spacer out - it slides up the shaft about 1/2 way but won't go any further which is not allowing it to come off. The shaft isn't bent and the bottom bearing looks to be in good shape. However, when I engage the deck, the spindle I repaired makes a ticking or clicking sound. When I spin the blade by hand, it spins free and doesn't make any noise. Any thoughts on what it could be?
