Simplicity 738 Broadmoor, rebuilding carb and trying to figure out what carb kit
738Broadmoor91
  • / Simplicity 738 Broadmoor, rebuilding carb and trying to figure out what carb kit
Believe the carb to be a 491590, thinking that Rebuild kit 796184 is what I need but not sure and I also need to rubber elbow that comes off of the carb. Any help is much appreciated.
738Broadmoor91
I'm sure anyone reading already knows but this is an 8 HP briggs
8 hp briggs narrows it down to about 500 variations. Model, type and code please.
738Broadmoor91
Ah my apologies, I posted in the middle of the night and no picture of the engine to pull numbers from but I'll post them now model 191700 type 2440 01 code 88060210
Carb repair part number 394698 for carb part number 491591. The parts diagram shows the carb to breather tube assembly but doesn't list a part number for it. It may be one of those items that is NLA.
738Broadmoor91
Waiting on the new carb kit, put a new spark plug in, tried tuning the carb a bit, can make it idle nearly perfect and run in first gear just fine (3 speed gearbox plus reverse) in 3rd it bogs down and dies out, I'm sure a fresh rebuild and correct tuning along with the new plug and air filter will result in it running smooth and like new
