Export thread
Simplicity 738 Broadmoor, rebuilding carb and trying to figure out what carb kit
#1
738Broadmoor91
Believe the carb to be a 491590, thinking that Rebuild kit 796184 is what I need but not sure and I also need to rubber elbow that comes off of the carb. Any help is much appreciated.
#2
738Broadmoor91
I'm sure anyone reading already knows but this is an 8 HP briggs
#3
8 hp briggs narrows it down to about 500 variations. Model, type and code please.
#4
738Broadmoor91
Ah my apologies, I posted in the middle of the night and no picture of the engine to pull numbers from but I'll post them now model 191700 type 2440 01 code 88060210
#5
Carb repair part number 394698 for carb part number 491591. The parts diagram shows the carb to breather tube assembly but doesn't list a part number for it. It may be one of those items that is NLA.
#6
738Broadmoor91
Waiting on the new carb kit, put a new spark plug in, tried tuning the carb a bit, can make it idle nearly perfect and run in first gear just fine (3 speed gearbox plus reverse) in 3rd it bogs down and dies out, I'm sure a fresh rebuild and correct tuning along with the new plug and air filter will result in it running smooth and like new
