Yes~!!!
I've done it with flap discs That's a horrid way to go. I hate flap discs.
I've done it on my milling machine. Get good result but the tooling is expensive and the vibration from the thin blade material shortens tool life.
I've done it with a 10" grinding wheel and water drip cooling. That's been my go to method for a while now.
BUT I JUST FELL IN LOVE with PFERD 00010 CC-GRIND-SOLID 7X7/8 SGP STEEL GRINDING DISCS. they make 'em to fit angle grinders too.
Using almost no pressure I bring the disc to the work and it takes the metal down past the chips from stones etc in absolutely no time giving me a ferocious edge.
I mean it is super easy and fast fast fast
- - - - - - - - - - It is so damn fast that you gotta hold back. - - - - - - - - - -
this is what I bought: https://www.amazon.com/gp/product/B08356S2Q8/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
They ain't cheap, but unlike flap discs, they last forever. I've sharpened my blades several times and the grinding disc is as good as new.
They are also the best at stripping mill scale off steel
Here is the 4 1/2" diameter w/ 5/8" arbor version https://www.amazon.com/PFERD-61171-...s=pferd+victograin&qid=1625603728&s=hi&sr=1-1
Here is a video showing how blistering fast these things are. Got to 3:50 isf you are in a hurry
