earnest t bass
HOW THE HECK DO I REMOVE THE BLACK BASE SHROUD SURROUNDING THE MOTOR ON MY 10515
Precisely..I think it is to direct the air from the flywheel down around the cooling fins
thats it seemed like i took of all bolts ill look againAre you talking about the black shroud under the gas tank shroud and below the pull starter?
If I remember right there are 4 bolts holding it on. I think it is to direct the air from the flywheel down around the cooling fins.
Regards
Jerry
a pic would help, but removing the bolts would be a good start..
