Shorted deck clutch??
Micah Haarhoff
from what i have read on this forum if you unplug it and run it and turn the clutch on and you don't blow a fuse it means that the clutch is bad if you do blow it then there is something wrong in the wiring such as its grounded somewhere.
You can do the same thing by using your VOM meter.
