Mike88se
- Oct 11, 2013
- 76
- 738
That's pretty much my idea of what priming a fuel system meansActually, it does not "prime" the carb, but pulls fuel through the carb, sends the excess back to the tank, and "purges" all of the air out of the carb for easier starting with the choke.
I've just about decided to write this blower off. I found a new carb from a similar EB blower. Installed it and the bulb pulls fuel through the carb. And it still doesn't even attempt to fire. The purge assy on the old carb wouldn't pull fuel so I know that was at least part of the problem. Now I have fuel, spark, and compression and no start. Maybe a timing issue or a stuck valve. I may check the intake valve and the key on the crank shaft to make sure it hasn't sheared.
