reynoldston
- May 23, 2011
- 92
- 5,705
You can also buy the hub and pulleys from tractor supply company also. You buy hubs with different hole sizes and them the pulleys come in different sizes which you weld together. You would still need a key but the new pullys use 2 set screws. To take the crankshaft to a machine shop you would have to disassemble the engine. This would also give you a good way to go through the engine for a overhaul.
You said (Got them both off and the new shaft is thicker.) so I don't under stand the last post? Are you not saying the crankshaft is thicker? or am I missing something.
