KrashnKraka
- Jun 15, 2015
- 6
- 352
Okay..try this on.
Where the drive pulley sits in relation to how/where an adaptor
sits on the new engine shaft is maybe critical to retain drive belt
alignment when the modded 'shaft/adaptor' is fitted.
A machinist would need to know the distance from base plate
to centre of drive belt pulley ("V") to be able to build the adaptor
"connection length".
The adaptor, after the drive pulley, will carry the clutch pack
and thereby the blade belt pulley, as per the original design.
So you would need to provide the machinist with the measure
for the length of the adaptor required to also mount the clutch pack.
Clearer?
KK
