I need help with adjusting the valves on my riding mower. I have sought out extensively the gap to set the valves, with varied opinions. Does anyone know what measurement to gap to OHV valve, for below mentioned motor?
Here are my specs:
model Number: 13AN77KS011/211 - Troybilt Pony 42inch
Motor:12 0511 ZA 23647 - Power Built 17.5 Gross HP 500 CC / Briggs-stratton
I would like to give this solution I have found to save anyone else from ever having to go through what it took to find this. thanks all
It took three full days, I found the measurements here at:
http://www.smallenginesuppliers.com...cal_shaft_engines/276781SingleCylinderOHV.pdf
Valve Clearance – Intake .003 - .005 in. (.08 - .13 mm)
Valve Clearance – Exhaust .005 - .007 in. (.13 - .18 mm)
Here are my specs:
