Self Propelled TORO Lawn Mower not working
Walu4life
When I pull the handle for the mow to self propel it doesnt. The mow continues to cut but its touugh pushing it up the hills. Any suggestions to what could possibly be the problem.
Re: Self Propelled TORO Lwan Mower not working
Broken drive cable? Worn gears? They both happened to me before.
scott47429
we need a little more info on the mower but i would look at the belt first see if its off or broken or streched also look at the cable good luck
Lohman mows lawns
Check to c if any sticks or clumps of grass r jamming it I have had the happen to my JD self proplel
Walu4life
Thanks guys!!! Ill take a look at it today and let you know how it goes...
Also, post the model number of the unit.
tangwaikam
Check if the self propel mechanism is driven by a belt. If so the belt must be slacken or loose or the grass gets into the groove of the pulley that drives the belt. If that is the case, clear the grass.
Good luck.
