TheLadyRides
- Aug 7, 2014
- 2
- 3
My so-called handyman was asked to change the oil on my zero-turn Toro. Afterward, I set out to mow the lawn (it's a big one). Near the end of the task, the mower stopped. I figured the grass was heavy, so I just started it up again and drove it into the shed. As I turned it off, I noticed that two of the three quarts of oil I had bought for the job had never been opened. I immediately poured the oil in, but now it won't start. This is the model with the Kohler engine. Of course the dealers say it can't be fixed, so I can kiss my nearly $3,000 goodbye. What can I do? Can it be fixed? Will the PB Blaster trick work?
