Thanks in advance. need to know how to test seat safety switch. zt1540 will only run with parking brake on. not having much luck finding problem. Interlock some one suggested, how to test it? Again thanks.
There is a connector near the seat.
Disconnect it.
Or... on the other end, put a little loop of wire, making it a continuous circuit...thus bypassing the seat switch.
Are you sure of this? Most seats work off the negative side thus in order for the seat switch to work like you are saying it would have to go through a relay. You know this much better then I because you must be looking at a wiring diagram?.
Get your testosterone fix somewhere else.
Disconnect it.
You could use your multimeter and connect it to the wires going to the seat...set meter to OHMs and push on the seat switch. It should show numbers...not OL...meaning the seat switch is working
