davbell22602
- Nov 27, 2011
- 152
- 1,324
917.275031
23hp vtwin Kolher command pro
Is anybody using a battery that has more than 300 amps on this tractor setup or similar to it? Bought a 300 amp new back in the summer. When we had all that snow this earlier this month it started up fine. Went to start it a few days later when temperatures were in the 20's had to use jump pack cause battery wasnt turning engine fast enough to start. Today I went to start it in 50 degree weather and it started right up. Starting wonder if I should have bought the 450 amp Duralast gold battery from AZ for $50. Would I shorten life on the stater if I did go to 450amp battery?
All connections are tight.
