markmarkscott
- Apr 4, 2013
- 3
I scored an older Scotts which they say was a John Deere builder. Single Briggs was blown. And not included in the sale. I installed a twin 18hp Briggs.
Issue---
There is a red and white wire coming from under the flywheel. I assume it is the alternator.
Off the dash of this Scotts is a red and yellow connection and a white and yellow.
I get the engine to run. Putting the yellow fire (carb kill) to ground or to the white connection on the yellow/white the engine quits.
Where do I hook up the red and white from the motor? To the red and yellow connection?
Couple of links to show the mower with the electrical. Pic 1, color is washed out. See the jumper? That is the yellow kill wire connected to a white wire which leads back to the dash.
User Media - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Here is the wires, you can see the two connections which I assumed went to the single Briggs motor. I jump the red from the flywheel to the red? And the white to the yellow on these connections?
I am getting ready to install the deck. The rear seat connection is jumped.
Thanks, just trying to wire this baby up.
Issue---
