wolf865
- Apr 4, 2021
- Threads
- 5
- 23
Had an oil leak develop on my Scott's 1642 and the JD service department told my wife it must be the head gasket so to replace it, we did. Discovered there was nothing wrong with the head gasket but replaced it anyway since we had it off. Leak was actually coming from the governor rod, will ask questions about that leak in a different post. Anyway, once we put the engine back together it now runs at a really high RPM! Almost afraid it's going to blow the engine apart. We had mistakenly first set the governor clockwise but then discovered it should have been set counter-clockwise which we corrected but it still runs at the higher RPM. We can adjust it down to a lower RPM for mowing but the throttle is almost 2/3rd below the normal fast position for that. A mechanic told us that having set the governor wrong that a "button" and maybe something else (flyweights?) may have fallen off inside the engine? Can't believe an internal part could come off that easy. So is he blowing smoke? He's recommending that we just go out and buy a new mower as ~$350-$400 isn't worth investing in a 20 year old mower. If his diagnosis isn't the case, what do we need to do to get this back to it's normal RPM while on fast? One unusual thing I've noticed is that the L shaped bar that attaches to the governor rod rocks back and forth anytime it's not on Chock, Fast, or Stop? The spring that's attached to the bottom of it rarely has any tension on it? Don't really see anything unusual about how we slipped the carb back on. Only the 2 metal rods came off of it but they're back where they should be.
