KlinkSanford
Got it going, thank you very much for your time helping me!
I hooked up the multimeter black lead to the main ground by the engine and then with the red lead I tested voltage to the battery B terminal on the key switch and got 12 volts, then I tested the S terminal that goes to the Starter, got 12 volts when I turned the key, also tested the L lights and got 12v with the key in the on position. All good!
Then I tested the green wire going into the module and no 12v. Then I re-set the multimeter as it gave an odd reading and I made a better connection to the module and turned the key and the engine turned over. So, I disconnected the multimeter and tried starting and it started right up. It works fine now. It looks like the green connection into the module circuit was loose or not making good contact and my playing with it got it to make better contact. The plastic on the module connector is cracked and brittle, it looks like I will have to clean it up and do something about making a more secure connection.
Once again, I thank you very much!
God Bless
God Bless
