scag stt wants to go forward and backwards at the same time
Dwellonroof
  • / scag stt wants to go forward and backwards at the same time
Well, I took the pump apart and found that the bearing cage is destroyed and half the bearings have dropped which explains the the forward/reverse stick not going all the way back and probably the erratic behavior.
I'll try to get a picture.
7394
Wow, that's what I like about my new 2800's having no shared reservior..
Dwellonroof
I’m hoping the spin on filter caught the particles but I did flush the rest of the system with diesel fuel.
Dwellonroof
Since the pump bearing is bad I ordered a new pump , flushed the system and blew out the lines put it back together with fresh oil and filter.
Everything is working like new again !!
