Dwellonroof
- Apr 23, 2018
- 6
- 46
Turf Tiger started left hydro starrted to whine and now is very jumpy even in neutral position.
Anyone with ideas???
Uh oh! Metal shavings in the reservoir is not a good sign.The level is up where it should be and the color isn't bad so I stuck a magnet in the reservoir and it came out full of metal shavings. Also I noticed when in the operator station the left drive stick wont pull fully to the rear without a lot of force and when I start the engine it stays engaged in reverse but if I up the rpm the left wheel keeps going into forward and reverse repeatedly.
@Hammermechanicman has the best advice. A shared reservoir can mean that the other pump has been contaminated.Machine is older (2015) maintenance has been kept up but the machine shares the same reservoir and I'm hoping the filter caught any other particles.
I now believe it is the pump.
Do you think the pump and wheel motor are bad?You need to remove every hydraulic line and flush them and then pull the pump and motors and check them. Does the system have a separate filter? You have one bad wheel motor for sure.
