Scag Liberty 48" Idler pulley has a slight bit of movement when wiggling it.
7394
  • / Scag Liberty 48" Idler pulley has a slight bit of movement when wiggling it.
Thanks to Everyone for their insight on this, (y)
barny57
It is Part # 483422, approx 1/18" side play, normal or not ? Only the one pulley.. May be beginning of very slight noise down there.
Only has 58 hours on it.
Replace it or you’ll end up wrecking your belt to
7394
Hadn't considered that. Thanks.
7394
When it warms up the idler pulley side play is all but gone tho,..
