Scag Disc Brake Pads
Hayward51
I have a 2018 Tiger Cat 2 with brake pads worn down. I've pulled the wheel and looked. I see no way to replace just the pads. They seem to be riveted on. Do you have to replace calipers to get new pads ?
According to the parts list you replace the whole thing.
Hayward51
Yes, I saw this parts diagram ($90.+) and found replacement pads ($28.+) online. I just haven't figured out how new pads would attach without re-riveting them on.
Yes they are riveted on
I reline most mower brakes because down here they are a stupid price
Stainless or Monel pop rivets will do the job quite well
I drill the bulk friction material clamped against the shoe then drill 3/4 through the pad with an end mill to get a flat bottomed hole .
Some other techs do the same but also use SikaFlex as a glue as well
IT is a mower , max speed 10 mph not a Farrari max speed 200 mph
Kinda figured they were riveted but I personally have not seen a Tiger Cat II in my shop yet. Most are just the older units.
Just stainless steel with stainless steel anvils will require a much heavier pop rivet tool than the simple hand rivet tool. I was installing 3/16 stainless anvils version here and had upgrade to a Big Daddy rivet tool. Justifying the tool cost for an one time project is hard but a shop that will use it several times a year is not a problem.
In this case I would have to see the brake pads before I even try such a thing as I would need to size the rivets.
Hayward51
Thanks for your replies. I considered riveting myself but I noticed it wasn't common rivets.
I have an air riveter I bought years ago when I moved in here and had to erect 3 garden sheds around 200 x 1/8 rivets in each shed.
One of the best tools I have ever bought
I also have one of those scissor action riveters and the Monel rivets take 2 pulls the stainless take 3
Aluminium ones would probably be strong enough but considering where they are I worry about corrosion so if you have to buy rivets, go for the Monel .
Also not the mandrels can be made of different metals as well, the stronger the mandrel the tighter the rivet will pull down .
I use monel to hold baffels in motorcycle exhausts .
The op might be seeing those solid type rivets. This type is either hammered or squeeze into place.
williambrohan37
We would like to know about your most recent visit to Home Depot. So please, tell us about your experience! Your insightful comments will help the shop keep enhancing its offerings to consumers.If so, Home Depot is interested in knowing your thoughts and suggestions. Home Depot Survey
