Hi Guys,
Problem fixed. In my case I had no power to brown (seat power) wire into the Control Module. This was just a loose connection in the main harness plug!
What I did deduce are the conditions the Control Module is looking for to allow cranking (all measurement at wires going into the Control Module):
• Control Handles Out, Brake On, Seat Switch Depressed, key in START position.
• The RED wire at the module provides BATTERY VOLTAGE to power-up the module - needs 12 volts
• The BLACK wire at the module provides GROUND to the module. Confirm good GROUND is present on BLACK wire at module connector.
• The ORANGE wire at the module is supplying BATTERY VOLTAGE from the LH & RH neutral (control lever) switches to the module- needs 12 volts
• The BROWN wire at the module is supplying BATTERY VOLTAGE from the seat switch to the module - needs 12 volts
• The PINK wire at the module is supplying BATTERY Voltage from the brake switch to the module - needs 12 volts
• The LT BLUE wire at the module is supplying BATTERY VOLTAGE from the PTO switch to the module - needs 12 volts
• The GREEN/BLACK wire at the module is supplying GROUND from the module to the start relay. Confirm good GROUND is present on GREEN/BLACK wire at the START RELAY.
• The GREEN wire at the start relay is supplying BATTERY VOLTAGE from the key switch to the start relay - needs 12 volts
When the above listed conditions are met, voltage will be supplied on the GREEN/WHITE wire from the start relay to the starter solenoid to engage starter.
Cheers, Pete
