- Nov 29, 2014
- 64
- 24,705
There is a good reason why I try to avoid this junk.
However got one in from a good customer who enjoys throwing away money on rubbish
At least to confirm with EU regulations the OM's for the 1E34FN engine state the durablity of the engine is 100 hrs.
Anyway back to the dilemma
This is the first ever to give me the dreaded white knuckles, after 1/2 hour I dropped it because I could not keep my hands closed, the vibrations were so strong
Does any one know what the max RPM is for this engine.
Currently it is doing a screaming 10,500 rpm & I do mean screaming .
Only specs I can find are 2600 - 3000 rpm for idle which looks good as the clutch comes in at 3500 .
And max power @ 7500 rpm
True to cheapness has an unbranded rotary valve carb with no numbers on it and no adjustments.
