Will it suprise you that I yuse about 100 gallons of the "old school" oil each year ?
Multigrades were originally made in order to use up the light grae oils that were essentially waste products, thus reducing the price of lubricating oils.
Apart from reducing the load on the starter multigrade oils offer noting, nada , nil , sweet f a , benefit over strait grades of oil.
So if you arn't trying to start in freezing conditions, there is little advantage.
In cars it is a bit different as to comply with EPA regulations engine must fire and start withing 2 complete revloutions so the thin oils allow easier starting.
The down side is the high temperature lubricating properties are totally dependant upon the integrity of the addative package and this is a difficult thing to qualify.
Synthetics are a bit different as their addative packages are a lot more stable than standard oils.
So basically you can run $ 20/ Qt synthetics without problems to replace the $ 4 /Qt standard grade oils .
But not the other way around.
