TiIngot
- Sep 9, 2022
- 52
Had same problem on my D105. Deck was bent where one of the spindles mounts holding the blade. Grandson must have hit something. (Make sure one blade is not bent first.). Remove the deck and turn it over. Rotate the blades by hand and see where they meet in the middle. They should match each others height where they almost touch in middle of deck. Even a 1/4 inch off will be noticed in your cut if one is off.Hello,
I have a John Deere S130 Riding Mower. My problem is that when I mow, the grass is cutting unevenly. I have checked the tire pressures and they are all good and even. I also checked the deck and it seems pretty balanced. You can see the weird cutting patter in the picture below. Please help!
Look at outer edge of the deck as you rotate the blades and try to determine which blade is off. Remove the blade and spindle. Use a wood block and heavy hammer to straighten the deck. Will need to hammer both sides until deck is no longer bent. Install blade and recheck. Adjust as necessary.
