the advice you were given is all correct, just have to figure which on of them is the problem, that long scraggly don't look good to cut maybe cut it more often and some of week will die off.
djvalade@gm, you cannot not stretch a belt, the backing on the belt will not allow that, you can make the belt slip, the slippage causes wear on the inside of the belt that will give the indication that the belt stretched
